Thx Passmark > Performance Test for an LOL today @ work.
  • moulderhere
    • Oct 2016
    I'm "testing" a dual xeon e5-2620 v4 cpu and 256GB ram with 480 intel ssd and Windows 10 Pro.
    I did the performance test using the trial software on CPU only.
    Results
    CPU Mark 19301
    Integer Math 45238
    Prime Numbers 86
    Compression 35078
    Physics 1448
    Cpu single threaded 1747
    Floating point 21195
    Extended instruction sse 1023
    Encryption 4955
    Sorting 19587
    The LOL came from the World Wide maximum that says its 17021 my CPU Markscore is 19301
    My percentile is 99%
    Thank you for the LOL today.
    Made my day brighter in this stupid insane rain we are having.
    Ciao!
    Strange, when i check the World Max for the CPU Mark I see a value of 38,528.
    That was from a dual CPU Xeon E5-2699 v4
    What version of PerformanceTest are you running, and does it have internet access to download the current max from the cloud?
    You are probably still in the 99% percentile however. Anything above 16,000 for the CPUMark is a big score (as at Oct 2016).
    • moulderhere
      • Oct 2016
      Hi David:
      I downloaded the trial version today off the site.
      I had to do the tests offline. I can hook it up temporarily and re-run the tests as well.
      • moulderhere
        • Oct 2016
        I just re-ran the tests for fun.
        Completely failed the video tests due to no actual graphics card (onboard matrox I think it is). (test result=fail)
        Memory tests weren't so great either. (test result=2444)
        CPU test result=19051
        2d Graphics mark=518
        Disk test=4143.
        Overall now 2685.1
        I downloaded PerformanceTest 9.0 trial, loaded it onto Windows 10 v1607.
        Thanks again for an LOL at work!
