difference of results between Disk Tests - PT8 and PT9
  • Hyperion
    • Feb 2017
    Hello Passmark,
    I am using your software for certain years now. I like the PT9 really.
    Can I compare the results of the hard disk tests from 8 to 9 directly or is there a difference?
    Thanks for your answer and all the things you do keeping on improving PerformanceTest.
    Elmar
    • 969
    You should be okay. There hasn't been any significant changes to prevent the Disk test results from V8 to be not comparable with V9.
    • Hyperion
      • Feb 2017
      Thank you for your quick answer!
