help with results - low integer maths
  • wannabenz
    • May 2012
    Hello all,
    i just ran a benchmark and used a comparison almost exactly the same machine running similar cpu speed, and on looking at results mine falls back badly with intega math and its a long way off the comparision ,i have uploaded results but i dont know how you can tell if its mine or not can i post them here? many thanx phil
    ill try posting here in txt
    Benchmark Results
    Test Name: This Computer
    CPU - Integer Math: 576.9
    CPU - Floating Point Math: 2619.9
    CPU - Find Prime Numbers: 1553.7
    CPU - Multimedia Instructions: 11.9
    CPU - Compression: 5692.4
    CPU - Encryption: 23.4
    CPU - Physics: 397.6
    CPU - String Sorting: 4743.8
    Graphics 2D - Solid Vectors: 2.9
    Graphics 2D - Transparent Vectors: 2.9
    Graphics 2D - Complex Vectors: 145.1
    Graphics 2D - Fonts and Text: 202.0
    Graphics 2D - Windows Interface: 113.1
    Graphics 2D - Image Filters: 464.1
    Graphics 2D - Image Rendering: 422.9
    Graphics 3D - Simple: 2540.9
    Graphics 3D - Medium: 1200.9
    Graphics 3D - Complex: 104.4
    Graphics 3D - DirectX 10: 46.5
    Memory - Allocate Small Block: 3690.2
    Memory - Read Cached: 2597.6
    Memory - Read Uncached: 2444.6
    Memory - Write: 1623.6
    Memory - Large RAM: 1726.6
    Disk - Sequential Read: 69.1
    Disk - Sequential Write: 69.1
    Disk - Random Seek + RW: 2.8
    CD - Read: 6.4
    CPU Mark: 4520.8
    2D Graphics Mark: 488.9
    Memory Mark: 1070.4
    Disk Mark: 510.3
    CD Mark: 787.6
    3D Graphics Mark: 2579.5
    PassMark Rating: 1683.8
    Number of CPU: 1
    Cores per CPU: 4
    CPU Type: Intel Core i5 750 @ 2.67GHz
    CPU Speed: 3612.3 MHz
    Cache size: 256KB
    O/S: Windows 7 (32-bit)
    Total RAM: 3582.1 MB.
    Available RAM: 2663.9 MB.
    Video settings: 1280x1024x32
    Video driver:
    DESCRIPTION: NVIDIA GeForce GTX 460
    MANUFACTURER: NVIDIA
    BIOS: Version 70.4.13.0.76
    DATE: 2-29-2012
    Drive Letter: C
    Total Disk Space: 266.2 GBytes
    Cluster Size: 4.0 KBytes
    File system: NTFS
    You are running 32bit Windows, which will lower some of the results.
    There is no reason to be running 32bit Windows on this machine as it has a relatively new CPU and at least 4GB of RAM.
    See also,
    http://www.passmark.com/forum/showth...-maths-amp-PT8
    http://www.passmark.com/forum/showth...chmark-results
    • wannabenz
      • May 2012
      help with
      i run 32 bit because some of my programs dont like 64 bit ie/printer does not work on quicken have asked them for a fix but nothing. but that set aside why is that integar math so low is that ok for 32 bit? tia
      See also,
        You can compare your results to the charts here,
        http://www.cpubenchmark.net/
        and to baselines you can download from within the software.
        Also 64bit Windows comes with both a 32bit and 64bit version of IE. So that should not be an issue. Any printer made in the last 5 years will have 64bit driver support.
