Concerns about PT v8_1054 vs v9_1013 results for the same PC
  • natey2
    • Apr 2017
    Most results are within a few percent of each other, so no real cause for concern, but:
    CPU Mark
    all were fairly close, but
    CPU - Extended Instructions (SSE)
    v8 reports 48
    v9 reports 370
    (big difference!)
    2D Graphics Mark
    Graphics2D - Fonts and Text
    v8 reports 160
    v9 reports 252
    3D Graphics Mark
    all were identical, but
    Graphics3D - DirectX 9 Simple
    v9 didn't do this test; v8 did
    Graphics3D - DirectCompute
    v8 reports 196
    v9 reports 384
    Memory Mark
    fairly consistent between v8 and v9
    Disk Mark
    very consistent between v8 and v9
    In version 9 of PerformanceTest the CPU extended instructions benchmark test will perform testing using sub-tests for FMA, AVX and SSE (or only those that are supported, for older CPUs) and take the average of the 3 (or of those that are supported) for the benchmark result. FMA and AVX are new CPU instruction sets that have become available over the last few years in Intel and AMD CPUs. They were designed to make certain mathematical operations faster.
    The newer instructions allow the same computations, matrix multiplications, in this case, to be performed much faster than before. On old CPUs the difference won't be as dramatic, as they likely won't support all the new instructions.
    There has also be lots of other changes in V9. Some of which impact the benchmark results.
