"Could not reset the Direct3D device" DirectX error fixed ;-)
  • scottfree1
    • Nov 2014
    Started getting an error running the 3d Directx 10 tests (v8 & v9) with a pop-up "Could not reset the Direct3D device. The dialog will now be closed." this is in the DirectX10 test, the test continues to run but with a 10% penalty.
    I canoodled around with drivers, settings etc. the usual suspects, but it turned out 2 be my dpi settings, if they are to high the test no longer fits on screen and throws the error, on my HP 30" monitor at 200 dpi I get the error but @ 175 dpi no error..
    See also
    https://www.passmark.com/forum/perfo...directx10-test
