Remote Execution Problems
  • plmanikandan
    • Apr 2006
    I am remotely executing the pt.exe using SSH.
    When we execute remotely, we won't get any messages in the remote system (pt.exe is running in the background of remote computer). Sometimes i get message "No cd detected in the selected drive(G.Please Insert a cd and try again". This message is not displayed in the remote computer as i am running thru SSH. How to give "Cancel" or "Retry" when we run thru remote or How to disable the CD test when there is no cd in that drive.
    Is there anyway where we can handle the message execution from remote computer.
    Mani
    At the moment no, there is no way to avoid the CD test if you are running the full set of tests.
    Nor did we envisage using SSH to run tests.
    Maybe you can use the built in Windows remote desktop feature?
