PerformanceTest could not access system management bios info
  • plmanikandan
    • Apr 2006
    I am getting the message "PerformanceTest could not access system management bios information" when i start the Performance test.Is there any way to solve this problem.I am using windows2003 server
    Manikandan
    It might be becuase you are not running as the admin user and so it can't load the device driver needed to get the SMBIOS details.
    It shouldn't effect the actual tests however. But you will be missing some system information (like the BIOS version).
    • plmanikandan
      • Apr 2006
      I logged as administrator while doing performance test,still giving the same error "PerformanceTest could not access system management bios information".I am using windows2003 server with service pack1.0.Is there any solution to solve this problem.
      Mani
        Can you make a debug file, by following the instructions here,
        http://www.passmark.com/support/pt5debug.htm
        and then E-mail it to use or post it.
        • plmanikandan
          • Apr 2006
          I am attaching the debug file as per your request.
          Environment in which i test performance test is below:
          Windows 2003 server with service pack 1
          I checked for the bios also, it is the latest. I also erased the bios and flash it with the new one from IBM website, but problems still persist.
          Expecting your reply at the earliest possible.
          Mani
          Content of debug file:
          0.000s - DEBUG: Starting...
          0.000s - DEBUG: PerformanceTest 6.0 build 1009
          0.016s - DEBUG OS: Windows 2003 Server (WIN32)
          0.016s - DEBUG Path: C:\Program Files\PerformanceTest
          0.016s - DEBUG Command line: "C:\Program Files\PerformanceTest\pt.exe" DEBUGMODE
          0.016s - DEBUG: Getting CPU info
          0.016s - CPU Cores 1: 4121
          0.016s - 0 - C: 2, L: 1, HS: 0, CP: 1
          0.016s - DEBUG: Get CPU info:17
          0.016s - DEBUG: Get CPU info Get Process (4294967295, 0)
          0.016s - DEBUG: Get CPU info Get Process Affinity Mask (1 0)
          0.016s - DEBUG: Get CPU info: dwProcessAffinity = 3, dwSystemAffinity = 3
          0.016s - DEBUG: Get CPU info:21
          0.016s - DEBUG: Get CPU info:22
          0.016s - DEBUG: Get CPU info:23
          0.016s - DEBUG: Get CPU info:24
          0.016s - APIC_ID 0, PHYS_ID 0, CORE_ID 0, LOG_ID 0
          0.016s - APIC_ID 1, PHYS_ID 0, CORE_ID 0, LOG_ID 1
          0.016s - 1 - C: 2, L: 2, HS: 1, CP: 1
          0.016s - 2 - C: 1, L: 2, HS: 1, CP: 1
          0.016s - DEBUG: GenuineIntel Intel(R) Pentium(R) 4 CPU 3.00GHz 2994.2 MHz
          0.031s - DEBUG: Init common controls
          0.031s - DEBUG: Opening splash window
          0.031s - DEBUG: Retrieving SMBIOS information
          0.031s - DEBUG: Loading device driver...
          0.031s - DEBUG: Remove driver failed
          0.187s - DEBUG: Locating SMBIOS header offset
          0.187s - DEBUG : Map P (000F0000) to L (01930000)
          0.187s - DEBUG: Unmap memory Device IO control
          0.187s - DEBUG: SMBIOS header found
          0.187s - DEBUG : Map P (000F66E0) to L (019366E0)
          0.187s - DEBUG: SMBIOS Start address V:019366E0 P:000F66E0
          0.187s - DEBUG: SMBIOS Version 2 34
          0.187s - DEBUG: SMBIOS numstructures, size 52 30
          0.187s - DEBUG : Map P (000EFC70) to L (0193FC70)
          0.187s - DEBUG : pbAddr 0193FC70
          0.187s - DEBUG : pbAddr[0] 0
          0.187s - DEBUG : SMB structure number 0 (Type: 0, Size: 46, Offset: 0
          0.187s - DEBUG : pbAddr 0193FC9E
          0.187s - DEBUG : pbAddr[0] 1
          0.187s - DEBUG : SMB structure number 1 (Type: 1, Size: 62, Offset: 46
          0.187s - DEBUG : pbAddr 0193FCDC
          0.187s - DEBUG : pbAddr[0] 2
          0.187s - DEBUG : SMB structure number 2 (Type: 2, Size: 17, Offset: 108
          0.187s - DEBUG : pbAddr 0193FCED
          0.187s - DEBUG : pbAddr[0] 3
          0.187s - DEBUG : SMB structure number 3 (Type: 3, Size: 43, Offset: 125
          0.187s - DEBUG : pbAddr 0193FD18
          0.187s - DEBUG : pbAddr[0] 4
          0.187s - DEBUG : SMB structure number 4 (Type: 4, Size: 98, Offset: 168
          0.187s - DEBUG : pbAddr 0193FD7A
          0.187s - DEBUG : pbAddr[0] 7
          0.187s - DEBUG : SMB structure number 5 (Type: 7, Size: 29, Offset: 266
          0.187s - DEBUG : pbAddr 0193FD97
          0.187s - DEBUG : SMB structure number 6 (Type: 7, Size: 29, Offset: 295
          0.187s - DEBUG : pbAddr 0193FDB4
          0.187s - DEBUG : pbAddr[0] 8
          0.187s - DEBUG : SMB structure number 7 (Type: 8, Size: 21, Offset: 324
          0.187s - DEBUG : pbAddr 0193FDC9
          0.187s - DEBUG : pbAddr[0] 126
          0.187s - DEBUG : SMB structure number 8 (Type: 126, Size: 21, Offset: 345
          0.187s - DEBUG : pbAddr 0193FDDE
          0.187s - DEBUG : SMB structure number 9 (Type: 8, Size: 24, Offset: 366
          0.187s - DEBUG : pbAddr 0193FDF6
          0.187s - DEBUG : SMB structure number 10 (Type: 8, Size: 24, Offset: 390
          0.187s - DEBUG : pbAddr 0193FE0E
          0.187s - DEBUG : SMB structure number 11 (Type: 8, Size: 26, Offset: 414
          0.187s - DEBUG : pbAddr 0193FE28
          0.187s - DEBUG : SMB structure number 12 (Type: 8, Size: 29, Offset: 440
          0.187s - DEBUG : pbAddr 0193FE45
          0.187s - DEBUG : SMB structure number 13 (Type: 8, Size: 30, Offset: 469
          0.187s - DEBUG : pbAddr 0193FE63
          0.187s - DEBUG : SMB structure number 14 (Type: 8, Size: 30, Offset: 499
          0.187s - DEBUG : pbAddr 0193FE81
          0.187s - DEBUG : SMB structure number 15 (Type: 8, Size: 29, Offset: 529
          0.187s - DEBUG : pbAddr 0193FE9E
          0.187s - DEBUG : SMB structure number 16 (Type: 8, Size: 29, Offset: 558
          0.187s - DEBUG : pbAddr 0193FEBB
          0.187s - DEBUG : SMB structure number 17 (Type: 8, Size: 29, Offset: 587
          0.187s - DEBUG : pbAddr 0193FED8
          0.187s - DEBUG : SMB structure number 18 (Type: 8, Size: 29, Offset: 616
          0.187s - DEBUG : pbAddr 0193FEF5
          0.187s - DEBUG : SMB structure number 19 (Type: 8, Size: 29, Offset: 645
          0.187s - DEBUG : pbAddr 0193FF12
          0.187s - DEBUG : SMB structure number 20 (Type: 8, Size: 24, Offset: 674
          0.187s - DEBUG : pbAddr 0193FF2A
          0.187s - DEBUG : SMB structure number 21 (Type: 8, Size: 25, Offset: 698
          0.187s - DEBUG : pbAddr 0193FF43
          0.187s - DEBUG : SMB structure number 22 (Type: 8, Size: 22, Offset: 723
          0.187s - DEBUG : pbAddr 0193FF59
          0.187s - DEBUG : pbAddr[0] 9
          0.187s - DEBUG : SMB structure number 23 (Type: 9, Size: 18, Offset: 745
          0.187s - DEBUG : pbAddr 0193FF6B
          0.187s - DEBUG : SMB structure number 24 (Type: 9, Size: 22, Offset: 763
          0.187s - DEBUG : pbAddr 0193FF81
          0.187s - DEBUG : SMB structure number 25 (Type: 9, Size: 26, Offset: 785
          0.203s - DEBUG : pbAddr 0193FF9B
          0.203s - DEBUG : pbAddr[0] 126
          0.203s - DEBUG : SMB structure number 26 (Type: 126, Size: 23, Offset: 811
          0.203s - DEBUG : pbAddr 0193FFB2
          0.203s - DEBUG : pbAddr[0] 9
          0.203s - DEBUG : SMB structure number 27 (Type: 9, Size: 26, Offset: 834
          0.203s - DEBUG : pbAddr 0193FFCC
          0.203s - DEBUG : pbAddr[0] 10
          0.203s - DEBUG : SMB structure number 28 (Type: 10, Size: 45, Offset: 860
          0.203s - DEBUG : pbAddr 0193FFF9
          0.203s - DEBUG : SMB structure number 29 (Type: 10, Size: 14, Offset: 905
          0.203s - DEBUG : pbAddr 01940007
          0.203s - DEBUG : pbAddr[0] 11
          0.203s - DEBUG: Unmap memory Device IO control
          0.203s - DEBUG: Shutdown Direct IO
          3.156s - DEBUG: Retrieving SMART information
          3.156s - DEBUG: Opening main window
          3.172s - DEBUG: Opened main window
          3.172s - DEBUG: Checking language and local
          3.172s - DEBUG: Got language and local
          3.172s - DEBUG: Getting video driver information
          3.187s - DEBUG VIDEO MFG: Intel(R) 82915G/GV/910GL Express Chipset
          3.187s - DEBUG VIDEO DESC: Intel(R) 82915G/GV/910GL Express Chipset Family
          3.187s - DEBUG VIDEO BIOS: Intel Video BIOS
          3.203s - DEBUG: Building device info strings
          3.203s - DEBUG: Getting memory information
          3.203s - DEBUG: Creating performance stats thread
          3.203s - DEBUG: Performance stats thread created
          3.203s - DEBUG: Initialising bitmap resources
          3.203s - DEBUG: Display welcome window
          3.203s - DEBUG: Building baseline list
          3.219s - DEBUG: Checking command line
          3.219s - DEBUG: Entering message loop
          3.297s - DEBUG PERF: Loading Perf DLL
          3.297s - DEBUG PERF: Found perf functions in DLL
          3.297s - DEBUG PERF: Loaded Perf DLL
          3.312s - DEBUG PERF: Host "CSS-XEN", Index 238, Counter 6
          3.312s - DEBUG PERF: Assembling counter string1 ""
          3.312s - DEBUG PERF: Counter string1 "\Processor(_Total)\"
          3.312s - DEBUG PERF: Counter string2 "\Processor(_Total)\% Processor Time"
          3.312s - DEBUG PERF: Got counter string DLL
          3.312s - DEBUG PERF: Finished query
          3.328s - DEBUG PERF: Added counter
          68.062s - DEBUG PERF: Initialize3DEnvironment
          79.359s - DEBUG PERF: Initialize3DEnvironment
          79.453s - DEBUG PERF: InitDeviceObjects
          79.453s - DEBUG PERF: InitDeviceObjects - Initialize the font's internal textures
          79.703s - DEBUG PERF: Init3DWater
          79.703s - DEBUG PERF: Entering surface
          80.141s - DEBUG PERF: BuildTerrainMesh 1
          80.156s - DEBUG PERF: BuildTerrainMesh 2 (16384)
          80.187s - DEBUG PERF: BuildTerrainMesh 3 (300)
          80.203s - DEBUG PERF: BuildTerrainMesh 4
          80.203s - DEBUG PERF: BuildTerrainMesh 5
          91.297s - DEBUG PERF: Initialize3DEnvironment
          91.531s - DEBUG PERF: InitDeviceObjects
          91.531s - DEBUG PERF: InitDeviceObjects - vertex shader 2.0 and pixel shader 2.0 unsupported
          91.531s - DEBUG PERF: InitDeviceObjects - Initialize the font's internal textures
          91.875s - DEBUG PERF: Init3DWater
          91.875s - DEBUG PERF: Entering surface
          92.297s - DEBUG PERF: BuildTerrainMesh 1
          92.297s - DEBUG PERF: BuildTerrainMesh 2 (16384)
          92.344s - DEBUG PERF: BuildTerrainMesh 3 (600)
          92.437s - DEBUG PERF: BuildTerrainMesh 4
          92.437s - DEBUG PERF: BuildTerrainMesh 5
          118.687s - Large RAM: TotMB 2432.000000, TotSec 2.805000, TestMem 393803776, AvailMem 4568655532150353920, TotMem 1063723008118.703s - DEBUG: Building device info strings
          118.703s - DEBUG: Getting memory information
          118.719s - DEBUG : GetDiskFreeSpaceEx 393949184
          118.719s - DEBUG : Creating test file (size 209715200, Numblocks: 12801)
          118.719s - DEBUG : Set file pointer (1)
          118.719s - DEBUG : Set End of File OK(1)
          118.719s - DEBUG : Write test file - start (err: 0)
          118.734s - DEBUG : Write test file - end (err: 0)
          123.656s - DEBUG : Write test file - File closed
          143.719s - DEBUG : Attempt to remove test file C:\~pttest0.dat (err: 0)
          143.750s - DEBUG : 2nd Attempt to remove test file C:\~pttest0.dat (err: 2)
          143.750s - DEBUG : Adv. disk test - end execute
          144.219s - DEBUG : GetDiskFreeSpaceEx 393949184
          144.719s - DEBUG : GetDiskFreeSpaceEx 393940992
          144.719s - DEBUG : Creating test file (size 209715200, Numblocks: 12801)
          144.719s - DEBUG : Set file pointer (1)
          144.719s - DEBUG : Set End of File OK(1)
          144.719s - DEBUG : Write test file - start (err: 0)
          144.719s - DEBUG : Write test file - end (err: 0)
          148.891s - DEBUG : Write test file - File closed
          169.219s - DEBUG : Attempt to remove test file C:\~pttest0.dat (err: 0)
          169.250s - DEBUG : 2nd Attempt to remove test file C:\~pttest0.dat (err: 2)
          169.250s - DEBUG : Adv. disk test - end execute
          169.719s - DEBUG : GetDiskFreeSpaceEx 393940992
          170.234s - DEBUG : GetDiskFreeSpaceEx 393932800
          170.234s - DEBUG : Creating test file (size 209715200, Numblocks: 12801)
          170.234s - DEBUG : Set file pointer (1)
          170.234s - DEBUG : Set End of File OK(1)
          170.234s - DEBUG : Write test file - start (err: 0)
          170.234s - DEBUG : Write test file - end (err: 0)
          174.359s - DEBUG : Write test file - File closed
          194.828s - DEBUG : Attempt to remove test file C:\~pttest0.dat (err: 0)
          194.859s - DEBUG : 2nd Attempt to remove test file C:\~pttest0.dat (err: 2)
          194.859s - DEBUG : Adv. disk test - end execute
          195.734s - DEBUG: Building device info strings
          195.734s - DEBUG: Getting memory information
          206.187s - DEBUG PERF: End perf startup
          206.187s - DEBUG: Leaving message loop
            This post was previously answered by email and this post has been updated to make this information available to forum users.
            We believe we have corrected this issue in PerformanceTest 6.0 1010. The new version can be downloaded from:
            http://www.passmark.com/download/pt_download.htm
            Ian
