Wrong CPU clock detection
  • IFeelYou
    • Jul 2017
    • 19
    Good day,
    today I got a Top 20 score at the 11th place: https://www.passmark.com/baselines/V...id=86468749996 , but my CPU clock detection for sure is very wrong. It shows clock at 3.0 Ghz which apparently is not true, cause it's 4.7 Ghz. All the time I'm getting wrong CPU detection with Rampage V and 5960X. Could You please fix it?
    And why GPU always shows only 1 card in Baselines. It was 980Ti SLI system, not single one, which is very important. Why it's impossible to detect and write true information about hardware?
    Thank You for Your attention, and good luck in Your work!
    Can you make sure you are using the latest version of the software. V9.0 (Build 1015) at the moment.
    Then can you post or EMail us a debug log file. Details are here
    https://www.passmark.com/support/ptdebug.htm
    • IFeelYou
      • Jul 2017
      • 19
      For sure I'm using version 1015. It is written on my baseline.
      I have sent both debug files (SysInfo and PerfLog) with CPU clock set to 4.5 Ghz.
      Maybe You can help me.
      Thank You very much!
        We don't seem to have received anything. Were the files sent?
        • IFeelYou
          • Jul 2017
          • 19
          sent in both info@ and help@
            Still nothing, I have white listed your @yahoo EMail address now. Try sending to david@.
            • IFeelYou
              • Jul 2017
              • 19
              Maybe Your antivirus blocks attachments? I'm attaching it here too.
                We sent you a new software build to try out. If you can let us know the results, that would be great.
                • IFeelYou
                  • Jul 2017
                  • 19
                  Now it's interesting. CPU clock (Turbo) gets recognized, but Total Physical Memory always shows 0. Only Used Physical Memory is shown.
                  • IFeelYou
                    • Jul 2017
                    • 19
                    All problems fixed in Build 1016 (CPU Turbo and amount of Physical Memory). Thank You very much Respect.
