Passmark doesn't detect my motherboard
  • Lugaidaway
    • Nov 2012
    I was testing mi PC, done every test and when I was going to update the results, the program says that I doesn't recognize my motherboard. It detects the BIOS and all the rest of the stuff... but not the motherboard, any suggestions?
    My Motherboard is a Gigabyte GA-970A-D3
    On the system information tab what does it display in the fields,
    "Motherboard Manufacturer"
    "Motherboard model"
    "Motherboard version"
    What was the exact message that you saw?
    There isn't a general problem with Gigabyte boards or this model. We have dozens of example baselines results where this model motherboard was correctly detected.
    • Lugaidaway
      • Nov 2012
      Well, that fields are... literally, empty, you can see on this image. And the message that pops up when i try to upload my baseline is this one. I don't know what I may be doing wrong, I search and they are many motherboards like mine into the passmark database :S
        We'll fix the upload function to allow null motherboard names.
        We are guessing that the reason it is null is because you are using the Spanish version of Windows and some of the internal strings we are searching for to identify the motherboard details have been translated into Spanish. We'll look into this a bit more and see if we can confirm this is the reason.
        • Lugaidaway
          • Nov 2012
          Oh, Ok, thanks for your time.
          • Michael (Passmark)
            • Apr 2007
            • 214
            After investigation, it seems this was a bug introduced in build 1007 that affected all systems (not just Spanish). Build 1008 has now been released to correct this issue.
            http://www.passmark.com/download/pt_download.htm
            • Lugaidaway
              • Nov 2012
              Oh, thanks for the new build
              Now it works fine
