Trying to run the Performance test 8 and half way through the monitor displays " Input not supported " . Can anyone point me in the right direction to solve this ?
Imput not supported
Tags: None
This sounds like the 3D test tried to switch to a resolution or refresh rate not supported by your monitor, which particular 3D test is triggering the error message?
Do you see the same behaviour in PerformanceTest 9?
