Issue with overall score calculation
  • dadyal
    • Nov 2017
    test with much lower individual score score high ?
    Machine on the left was significantly slower on 2D and memory scores. But faster in other areas.
    Memory score in particular would have hurt the overall result.
    You can find the formula for the overall score here
    https://www.passmark.com/forum/perfo...-and-disk-mark
    The algorithm is designed is such a way that you can't get a great overall score without having all the individual scores also being great. It is a Weighted Harmonic Mean.
    • dadyal
      • Nov 2017
      the problem is 2d clock is joke amnd cpmputer with 50% highier score is running 2133mhz dd3 ram with i7 4790k while computer with lower ram score is running 2933mhz ddr4 with ryzen 1800x 50% more 3d score did not do anything neither did 600% more disk speed but 2d clock and ram did wich does not even make sense how 2133mhz ddr3 is faster than 2933mhz dd4 ?
        RAM benchmark is a combination of the RAM sticks, the CPU (including the single threaded performance), the BIOS settings, the number of RAM channels and the amount of free RAM.
        Some of the Ryzens have really bad RAM latency and relatively poor single threaded performance.
        • dadyal
          • Nov 2017
          here is
          3770k @ 4.5 ghz with 2133mhz DDR3 ram vs Ryzen 1800X @ 4.0 ghz with 2933 mhz DDR4 ram
