Memory Mark and 2D Mark Very Low Score Compared to Same Model
  • presnotsure
    • Aug 2018
    • 7
    I am trying to figure out what is wrong. My CPU, 3D graphics, and disk benchmarks look good. However, my 2D graphics and memory benchmarks are terribly low compared to benchmarks with the same hardware. What could be causing this problem? Is it possible that this memory is not compatible with my other hardware?
ID:	42738 Click image for larger version
ID:	42739 Click image for larger version
    9.0 (Build 1026) WIN64
    2081
    DESKTOP-NNN880B
    Windows 10 Professional Edition build 17134 (64-bit)
    Gigabyte Technology Co., Ltd.
    AB350M-DS3H-CF
    x.x
    American Megatrends Inc.
    F23
    2018/08/08
    AuthenticAMD
    AMD A8-9600 RADEON R7, 10 COMPUTE CORES 4C+6G
    Carrizo
    Family 15, Model 65, Stepping 1
    AM4
    28nm
    1
    4
    1
    3180.5 MHz [Turbo: 3486.7 MHz]
    15.5X
    205.2 MHz
    (N/A)
    1.000
    4 x 32 KB
    4 x 96 KB
    4 x 1024 KB
    (N/A)
    7119MB
    4503MB
    4GB DDR4 SDRAM PC4-19207
    G Skill Intl F4-2400C15-4GNT
    XMP: 1.20V, Clk: 1200.5MHz, Timings 15-15-15-35
    C:\pagefile.sys (1792MB)
    SPCC Solid State Disk
    238GB
    C:
    SATA
    512
    Solid State
    D6280787120B01417840
    SanDisk Extreme USB Device
    58GB
    D:
    Unknown
    Unknown
    Unknown
    Unknown
    ATAPI iHAS124 F
    C: [Local Drive]
    NTFS
    4KB
    237.9GB (210.7GB)
    D: [Removable]
    32KB
    E: [Optical drive]
    CDFS
    AMD Radeon R7 Graphics A8-9600 RADEON
    No
    AMD Radeon Graphics Processor (0x9874)
    Internal DAC(400MHz)
    1024MB
    109-C95010-003
    Advanced Micro Devices, Inc.
    24.20.11020.2
    5-29-2018
    1440x900x32 60Hz 96 DPI (Primary monitor)
    32.0C (Maximum: 32.0C)
    33.0C (Maximum: 33.0C)
    30.0C (Maximum: 45.0C)
    The AMD CPUs have slower memory access compare to Intel CPUs (generally speaking).
    So if you look at all results for a particular model of RAM, the Intel CPUs (and thus the overall average) will be higher than AMD CPUs.
    You should also check you are using the correct motherboard slots to get dual channel and are using XMP if it is available.
