Lower score when overclocking?
  • nguyen430
    • May 2006
    I have a Pentium D 940 (3.2GHz) overclock 3.62GHz scores 570.
    However, when I overclock it to 3.72GHz the score is 480.
    Do you think the system is slowner with more overclocking like this?
    Thanks.
    • 11118
    You would need to look at the individual results to see why it slowed down or if it was just a bad benchmark run (e.g. there was some background software running at the same time).
    • nguyen430
      • May 2006
      I looked at every test category. Each of them is slower including the CPU test!
      I "feel" the faster clock run faster, but the test gave the lower score consistantly overtime.
      Should I lower my clock to 3.62GHz?
      My system:
      Antec P150
      Abit IL8
      2GB Patriot 677MHz memory
      Pentium D 940 @ 3.72GHz
      Winfast 7600GS
      2 200GB Maxtor
        • 11118
        Maybe the CPU is overheating and throttled down.
        • nguyen430
          • May 2006
          Alright
          I replace the Intel CPU fan with a Zalman fan and boost the overclocking to 4.00 GHz and the score is now 627.
          Thanks Admin,
