Noticeably lower performance index of processor unit
  • BeLzEbUb
    • Dec 2013
    Hello, if I do complete CPU benchmarks only in PT I'm getting repeatedly noticeable lower values (about in 6600-6800 range) than is the common average (>7900 points). What might be on cause or is this influenced by other factors/MoBo/components? Any chance to tune it to perform on usual performance indexes?
    Averaging totals here: http://www.cpubenchmark.net/cpu.php?...MQ+%40+2.40GHz
    Temperature, voltage and clock seem all be in good operating ranges.
    See this post to start with,
    If this is a laptop, check the power management setting, make sure you aren't running on battery power. Also if you were running 32bit Windows, this could be the cause.
    • BeLzEbUb
      • Dec 2013
      Thanks for the reply, this is a laptop. And unfortunately none of mentioned apples to my situation. Laptop is new so there's no junk yet, having new drivers and 64bit OS.
      - running on AC main, power profile balanced which allows 100% CPU utilization
      - No processes that could throttle performance test
      - also it is supposed no other components should be influencing the index because this was only CPU tests.
