PerformanceTest 10.0 build1002
  • OldMike65
    • Mar 2017
    • 14
    Just updated my registered copy of PerformanceTest and now the screen shows a msg I've never seen before....I should not be seeing this screen. Never had this issue until your latest release yesterday....see pic.
  • OldMike65
    • Mar 2017
    • 14
    Click image for larger version  Name:	Latest Update.png Views:	0 Size:	44.5 KB ID:	46852
    This is new issue with latest update.
      Some of the cached histogram data files were being created incorrectly, the ones on our server are now up to date however you will still have a local copy with your install. If you delete the contents of the "C:\ProgramData\PassMark\PerformanceTest10\Cha rt Data" folder it should then re-load the required data from our server and display most of the charts.
      Some of the newer test (PDF / SVG rendering, 4KQD1 disk test) require an updated build which will likely be released later today.
      Edit: New version is available for download. So should be fixed now.
