Extremely low 2D graphics test
  • Thunderpoke
    • Apr 2020
    I did the performance PassMark test recently and my computer performed as expected apart from the 2D graphics test which scored VERY low.
    Does any know what caused this?
    Running on windows 10
    CPU
    Intel Core i7 6700 @ 3.40GHz AM
    16.0GB Dual-Channel Unknown
    Motherboard
    ASRock Z170 Pro4 (CPUSocket)
    Graphics
    4095MB NVIDIA GeForce GTX 1070 Ti
    Storage
    1863GB TOSHIBA DT01ACA200
    931GB Samsung SSD 970 EVO 1TB
    Is this Win7?
    Some test scores and the 2D mark value in older versions of Windows (eg Windows 7) will be far lower in PerformanceTest V10 as it isn't possible to scale meaningfully when multiple tests can't be run.
    Newer versions of Windows have added more available drawing APIs such as PDF and SVG rendering functions. The PDF and SVG test will not be able to run in Windows 7 at all due to missing Windows API functions. The DX11 parts of the Image Filters and Image Rendering test may be able to run in Windows 7 if DX11 is installed and a DX11 compatible video card is being used.
    • Thunderpoke
      • Apr 2020
      Im running windows 10
        Have a look at the individual 2D results and see which ones you are low for.
