Low CPU mark test, mainly Floating Point Math.
  • pepperedmoose97
    • Apr 2020
    Hi there
    sorry if this is the wrong place to ask, but i'm currently having issues with my Cpu's speed since the start of this week.
    after running numerous tests and finding PerformanceTest software, ive found that my CPU's Floating Point Math score is extremely low from what it should be, along with other cpu based scores as well as numerous video games i use this system for.
    i'm running the 64Bit version of the software on a 64 bit system, along with specifications at the bottom of this post if they're helpful. If you would like a log report from PT software id be more than happy to provide it as well.
    Thanks, Alex.
    What were all the CPU scores?
    • pepperedmoose97
      • Apr 2020
      CPU mark: 4364
      integer math: 21055
      floating point math: 2099
      prime number: 24
      extended instructions (sse): 6240
      compression: 129563
      encryption: 2971
      physics: 509
      sorting: 15312
      CPU single thread: 2114
      cross platform mark: 6439
      these do fluctuate a little bit as expected, but nothing like a huge jump in figures.
      picture is attached if you need it.
        Yes, something is really wrong.
        See this post to start with
        https://www.passmark.com/forum/perfo...-for-a-slow-pc
        But it might be this issue
        https://www.passmark.com/forum/perfo...int-math-score
        https://www.passmark.com/forum/perfo...-on-cpu-and-2d
