Computer extremely slow all of sudden low passmark score
  • XBlueish
    • May 2020
    Was fine couple days ago all of sudden my pc became extremely slow
    Reformatted couple times too with remove everything option
    So most likely hardware issue i think?
    Ran the passmark and the score seems to be pretty low for my spec aswell
    Mainly use this pc for gaming
    reformatted, updated all drivers and i still cannot smoothly run any games
    PUBG for example the fps drop constantly from 180+ to like 10-20ish
    Is it because my GPU is dying resulting slowing everything down?
    Operating System: Windows 10 Professional Edition build 18363 (64-bit)
    Motherboard Manufacturer: MSI
    Motherboard Model: Z170A GAMING M9 ACK (MS-7966)
    Motherboard Version: 1.0
    BIOS Manufacturer: American Megatrends Inc.
    BIOS Version: 1.60
    BIOS Release Date: 2016/02/24
    Type: Intel Core i7-6700K @ 4.00GHz
    Codename: Skylake
    CPUID: Family 6, Model 5E, Stepping 3
    Socket: LGA 1151
    Lithography: 14nm
    Number of CPU's: 1
    Cores per CPU: 4
    Logicals per Core: 2
    Clock Frequencies:
    Measured Speed: 4008.2 MHz [Turbo: 4108.4 MHz]
    Multiplier: 40.0X
    Bus Speed: 100.2 MHz
    Front Side Bus Speed: (N/A)
    Timing Error Ratio: 1.000
    Cache per CPU package:
    L1 Instruction Cache: 4 x 32 KB
    L1 Data Cache: 4 x 32 KB
    L2 Cache Size: 4 x 256 KB
    L3 Cache: 8 MB
    Memory Information:
    Total Physical Memory: 30GB RAM
    Available Physical Memory: 25GB RAM
    Memory Devices:
    Slot 1: 8GB DDR4 SDRAM PC4-25600
    Corsair CMU16GX4M2C3200C16
    XMP: 1.35V, Clk: 1600.0MHz, Timings 16-18-18-36
    Slot 2: 8GB DDR4 SDRAM PC4-25600
    Slot 3: 8GB DDR4 SDRAM PC4-25600
    Slot 4: 8GB DDR4 SDRAM PC4-25600
    Virtual Memory: C:\pagefile.sys (4864MB)
    Drive Information:
    Physical Drive 0: ST4000DX001-1CE168
    Drive Size: 3726GB
    Partitions: C: E: F:
    Interface Type: SATA
    Bytes per Sector: 512
    RPM: 5900
    Physical Drive 1: Samsung SSD 850 PRO 256GB
    Drive Size: 238GB
    Partitions: G:
    RPM: Solid State
    Optical Drive 1:
    Volume Information:
    Volume 1: C: [Local Drive]
    File System: NTFS
    Drive Cluster Size: 4KB
    Volume Size (Free space): 1772.9GB (1683.5GB)
    Volume 2: E: [Local Drive]
    File System: NTFS
    Volume Size (Free space): 976.6GB (976.3GB)
    Volume 3: F: [Local Drive]
    File System: NTFS
    Volume Size (Free space): 976.6GB (976.4GB)
    Volume 4: G: [Local Drive]
    File System: NTFS
    Volume Size (Free space): 140.8GB (139.0GB)
    Video Adapters:
    Video Card 1: NVIDIA GeForce GTX 1080
    SLI/Crossfire Enabled: No
    Chip Type: 0x1B80
    DAC Type: Integrated RAMDAC
    Memory: 8191MB
    Driver Provider: NVIDIA
    Driver Version: 445.75
    Driver Date: 3-17-2020
    Monitor 1: 1920x1080x32 60Hz 96 DPI (Primary monitor)
    Temperatures:
    CPU 0: 29.5C (Maximum: 39.5C)
    CPU Core 0: 30.0C (Maximum: 42.0C)
    CPU Core 1: 29.0C (Maximum: 39.0C)
    CPU Core 2: 27.0C (Maximum: 37.0C)
    CPU Core 3: 32.0C (Maximum: 40.0C)
    Hard Disk 0: 27.0C (Maximum: 27.0C)
    Hard Disk 1: 23.0C (Maximum: 23.0C)
    Hard Disk 2:
    GPU 0: 28.0C (Maximum: 49.0C)
    And my passmark rating
    Passmark rating
    3246.5
    cpu mark
    9295.2
    2d graphics mark
    963.8
    3d graphics mark
    15890.5
    memory mark
    3150.7
    disk mark
    819.5
    Any help would be appreciated
    Average CPU Mark for the 6700K is 9338 at the moment. So you are very close to average.
    Average 3D Mark for the 1080p is 14,654 at the moment. So you are above average.
    Your disk result for C:\ drive is rubbish, but that is because your larger HDD is rubbish (in the performance department). Obviously capacity is good.
    Those temperatures are from when the machine is idle I suspect. You might want to check temps under load.
    • XBlueish
      • May 2020
      What about the ssd? Cause my last reformat ive chose the SSD as primary window C drive but problem remains
      As for the temp its usually around 40-50 under load
        You can select the hard drive to be tested from the Preferences window.
        • XBlueish
          • May 2020
          Sorry, how to do that ?
            Menu item, Edit / Preferences.
            • XBlueish
              • May 2020
              Think i've found the problem
              My GPU is somehow stuck at 0.8ghz even under cpu benchmark
              It still stuck at 0.8ghz
              Is it possible that my cpu is burned by any chance?
                Sorry I don't see the logic.
                If you GPU is stuck at 800Mhz (and I didn't see any evidence of that in the benchmarks), then why would that be a CPU problem? More likely it would be a GPU cooling issue.
                • XBlueish
                  • May 2020
                  Thanks a lot guys
                  I've found and fixed the problem
                  Somehow my motherboard's "slow" option was triggered and locked my cpu on low performance. All i had to do was go to bios and disable "Intel Adaptive Thermal Monitor" option and everything was fixed itself. Thanks for the help guys
