Cpu not used
  • Simone
    • May 2014
    Cpu not used
    I do the CPU-test but on the taskmanager the usage is 24%. Is my PT result to low or how can I force the CPU to work with 100%?
    By default, the CPU tests loads up all available CPUs. The exception is if you edit the number of processed in the Edit / Preferences window, or when you are running the single threaded test.
    If your result is low, see this post to start with,
