First run - Opteron 146
  • Psydrop
    • Jul 2006
    I scored 1455 how does it stand out in here?
    Opteron 146
    2gb Ocz
    Xfx 7800gt
    36gb Raptor
    2*320 Raid 0
    //Psydrop
  • haelian
    • Jul 2006
    Not much info to go off of, but judging from what you gave, your score is higher than it should be. If your CD Mark is much higher than it should be (2000+) then these topics might explain why:
    http://www.passmark.com/forum/viewto...60ff2d0740c8fd
    http://www.passmark.com/forum/viewto...?t=450&start=0
    It could also be that you're passing a RAM disk off as a CD drive.
    http://www.passmark.com/forum/viewtopic.php?t=520
      Yes, boasting about your hardware is all well and good, but it is much more impresive if details of the configuration are posted with the actual indvidual results.
      • Psydrop
        • Jul 2006
        it wasn't about showing of...i just wanted a straight answear....i will give you a new tun tomorrow and we'll see.
          In our baseline database there are 53 different Sempron machines to compare your machine to. (but you need to purchase the software to use the database)
          A typical score would be 400 - 650 for an Opteron 146.
          If you are using PerformanceTest V6 32bit. A score of 1455 for this hardware is very high. Too high to be believed in fact. So most likely one of the individual results has been manipulated. (e.g. the old run my CD as a RAM drive, and don't disclose it to anyone trick).
          • Psydrop
            • Jul 2006
            Hi about the ram drive i saw i when i looked at it. If i find the time i will run the opty under Vappo.
