PT for Android no result?
  • wonderwrench
    • Oct 2007
    • 264
    Disk tests run and individual results are shown but no overall disk results or overall PT results are shown. App just updated today. Samsung S10+ with latest updates. Thanks for your time.
  • wonderwrench
    • Oct 2007
    • 264
    App version 3.0.1004 BTW.
      • 969
      What are you internal disk test result numbers? For PerformanceTest Mobile for Android on the disk test, we try to open a file with read/write cache disabled, but it is sometimes not supported or not honored by OS. If disk cache is enabled or we detect that the read speed is 20X factor then no disk mark is calculated/shown.
      • wonderwrench
        • Oct 2007
        • 264
        I bet that is the problem.
        • wonderwrench
          • Oct 2007
          • 264
          I can see the reason for disabling the cache but since most phones will most likely not allow disabling caching (s10+ does not) is it not breaking the app? No overall results?
            • 969
            Your test values shouldn't have triggered the cache detection. So I went to review the code. It seem there were remnants of some debug code that got submitted with the last build release that was incorrectly calculating the disk mark. I have submitted a fix to the play store and it should hopefully be rolled out shortly. We'll also update the disk mark for any submitted baselines for V3.0 Build 1004 in our database as well.
            We have some other changes planned for PerformanceTest family of software and it will likely revisit the cache issue and allowable read/write speeds. Thanks again for bringing this to our attention.
            • wonderwrench
              • Oct 2007
              • 264
              I got the new build and the problem is fixed! Thanks
