Test Memory speed per access step size
  • brod9gnik
    • Dec 2014
    i need help, guys, why peak is reached on the second step size?
    That would be the most efficient step size for your hardware.
    • brod9gnik
      • Dec 2014
      i need know why it most efficient.
      I have such question at examination
      i have Pentium Dual-Core E5300 2.6Ghz
      L1 Data cache 2 x 32 KB
      L2 1 x 2 MB
      2 x 2GGb DDR2 SDRAM
        It is complex to fully explain it.
        CPUs (and motherboard, RAM & cache) are designed to read at least 4 bytes at a time. Further they are optimised to read sequentially through RAM. Or if not sequentially, then optimised to read values close to the last value read. e.g in the same memory row.
        So reading 1 byte at a time tends to be slow. But reading at 4 bytes intervals tends to be quick. As the distances between memory accesses get larger, the system gets slower.
        Background reading:
        http://en.wikipedia.org/wiki/Locality_of_reference
        http://en.wikipedia.org/wiki/CPU_cache
        http://en.wikipedia.org/wiki/Prefetch_buffer
        • brod9gnik
          • Dec 2014
          Thank u, so in time answer, 1 hour to exam
