Can PerformanceTest V8 display temperature as Fahrenheit degrees?
  • jpcallan
    • May 2011
    Can PerformanceTest V8 display temperature as Fahrenheit degrees? In the USA we still use the Fahrenheit scale for most routine temperature measurements. Many of use don't have an innate sense whether 32C is hot or freezing cold.
    If you Google "32C Fahrenheit", then it will covert it for you. (89.6F)
    0C is freezing point
    100C is boiling point.
    But it would indeed be better if we had an option in the preferences window for imperial measurements.
