RTX 3070 low 3D score
  • Clarityjuice
    • May 2022
    Hi there,
    I have and RTX 3070. My score is rather low from the other baselines. Especially DX12. Previous card was a 1080.
    CPU: i5 10400
    Storage: NVME
    PSU: 650 Watt Bronze XFX
    Is my score more or less in-line with other 3070's?
    • 969
    As you said, your scores look okay except for the DX 12 tests. What resolution are you running at? The DirectX 12 tests at 4K resolution, if your monitor does not support the resolution, it will be penalized.
