CommandLine : Script + Output result
  • Sannazzarotiti
    • Jul 2015
    I would like to execute specific test AND have an output result.
    I tried this : PerformanceTest64.exe /s "c:\Script.ptscript" /ac "result.csv"
    it give me the csv but he execute all tests. If i use only /s "c:\Script.ptscript", it's working...
    How can i use both parameters in my command line ?
    Thanks for your help..
    As mentioned in the /a Auto-Launch description, The /a options can not be used with the /s option.
    When using a script you can use the EXPORTCSV command to save the results in a CSV file and the EXIT command to exit PerformanceTest after the tests have finished.
    • Sannazzarotiti
      • Jul 2015
      It's perfect, i didn't saw it in the documentation, i should take care (i find it now). Thanks for this answer.
      Have a good day
