Submit PassMark baseline from virtual machines
  • Karl.bonhme@gmail.com
    • Jul 2023
    Hello!
    My company just bought PerformanceMark and wow, this thing really is nice. Really a great job
    I have a quick question for you. I'd like to send my baselines to the website using the API keys but I can't without having all the test run. Is there a way to remove this limitation? It is impossible to run all the 3d tests from within the virtual machines.
    Thanks!
    • 337
    You should be able to upload a baseline without running 3D tests:
    https://www.passmark.com/baselines/V...d=187017844516
    Was there other tests that didn't run?
    As a workaround, try manually uploading with the 'Baselines > Submit baseline to Passmark' option.
