burnin Correlation between load running and power consumption
  • lookllokooo
    • Jan 2024
    When I ran the burnin 10.2 version on multiple 12450H hosts and 12650H hosts, the test content was as follows.
    1. Run the BurnInTest program, run [CPU Test] [2D Graphics Test] [3D Graphics Test] [Disk] [Memory Test] [Video Playground] [GPCPU Test] [Sound] test, pull the CPU load
    2. AID 64 view the CPU power consumption, CPU power consumption is about 31-32w​
    When I use 2x16g memory, I can run to 40w (PL 1 = 40 w, PL 2 = 40 w), and When I use 8g memory, I can only run to 33w(PL 1 = 40 w, PL 2 = 40 w). Is this a normal phenomenon? What causes this phenomenon?thank you
