Rankings of CPUs for individual tests
  • 137ben
    • Oct 2015
    Hello PassMark forum.
    The Cpubenchmark rankings list processors by their "cpu mark" score. From what I can tell, this arbitrary scale is an aggregate of eight different tests. Some of the tests are likely more relevant to my interests than others.
    Is there a way to view the rankings of processors based on their performance on just one of these tests? For example, could I see which processors do best on just the compression test? Could I see a ranking of cpus by their performance on the prime number test used PassMark's performance test?
    Thanks in advance.
    The individual results are visible in the PerformanceTest software. You can download baseline files for the best CPUs and then compare the individual results.
