Getting error while running script
  • sushant
    • Jun 2024
    I am running the test in Azure cloud, but it got stuck because to this popup, Is there any flag so test should run always?
    PS C:\Program Files\PerformanceTest> .\PerformanceTest64.exe /NO3D /s C:\perftest\GenerateBaseResult.ptscript /i
    PS C:\Program Files\PerformanceTest>​
    Script:
    # Set the computer name
    SETCOMPUTERNAME "MyComputer"
    SUPPRESSWARNINGS OFF
    SETDISK "C:"
    SETDURATION 20
    SETITERATIONS 1
    SETCPUTESTPROCESSES 1
    # Clear previous results
    CLEARRESULTS
    # Run the specified tests
    RUN ALL
    #RUN CPU_ALL
    #RUN G2D_ALL
    #RUN ME_ALL
    #RUN DI_ALL
    EXPORTBASELINE "C:\PerformanceTest\baseline_data.ptx"
    EXPORTHTML "C:\PerformanceTest\results.html"
    EXPORTCSV "C:\PerformanceTest\results.csv"
    EXPORTCSV "C:\PerformanceTest\results_all.csv"
    EXPORTTEXT "C:\PerformanceTest\results.txt"
    EXPORTTEXTF "C:\PerformanceTest\resultsF.txt"
    EXPORTIMG "C:\PerformanceTest\result.jpg" JPG
    # Suppress warnings off
    EXIT
ID:	57230Hardware software details:
    System information - MyComputer
    PerformanceTest Version
    PerformanceTest 11.0 1014 64-bit
    Number of processes used for CPU Tests: 2
    System Summary
    Windows 11 Professional Edition build 22000 (64-bit)
    1 x Intel(R) Xeon(R) Platinum 8171M CPU @ 2.60GHz [2095.2 MHz]
    8.0GB RAM
    16GB SSD, 150GB SSD
    DVD
    General
    System Name: MVM6666df23eaa
    Motherboard Manufacturer: Microsoft Corporation
    Motherboard Name: Virtual Machine
    Motherboard Version: Hyper-V UEFI Release v4.1
    Motherboard Serial Number: 0000-0012-7172-6990-7467-9960-08
    BIOS Manufacturer: Microsoft Corporation
    BIOS Version: Hyper-V UEFI Release v4.1
    BIOS Release Date: 03/08/2024
    BIOS Serial Number: 0000-0009-5644-5110-1938-5658-48
    CPU
    CPU Type: Intel(R) Xeon(R) Platinum 8171M CPU @ 2.60GHz
    CPUID Family 6, Model 55, Stepping 4
    Physical CPU's: 1
    Cores per CPU: 1
    Hyperthreading: Enabled
    CPU features: MMX SSE SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 DEP PAE Intel64 VMX AES AVX AVX2 FMA3
    Clock frequencies:
    - Measured CPU speed: 2095.2 MHz
    - Base Clock: 100.0 MHz
    Cache per CPU package:
    - L1 Instruction Cache: 1 x 32 KB
    - L1 data cache: 1 x 32 KB
    - L2 cache: 1 x 1024 KB
    - L3 cache: 35 MB
    Error:
    Invalid video mode. The resolution and color depth you have selected do not appear to be valid for hardware acceleration. Please ensure that the correct monitor drivers are installed. Also ensure that the most recent video drivers for your graphics adapter are properly installed. This error can also occur if your monitor is in portrait mode. Error Code: D3DERR_INVALIDCALL
    Does it make any sense to test 3D rendering performance at 4K resolution on a Azure cloud machine that has no monitor connected?
    Or were you just hoping for an option to skip the tests with errors silently to enable better automation?
    As your script hints at, you can run each test suite individually, without attempting the 3D tests.
    RUN CPU_ALL
    RUN G2D_ALL
    RUN ME_ALL
    RUN DI_ALL​
    Also makes me wonder what video card type they are emulating on this Azure instance & does it fully support DirectX9, 10, 11 and 12.
