Benchmark management
  • Strahan
    • Sep 2024
    Hi.
    Is there any easy way to load benchmarks other than one by one? I have 15 machines, and when I want to compare them, it's a major PITA to have to keep doing file, load benchmark, select PC. I tried to automate it with AutoHotKey, but it can't seem to send keystrokes to this program. So I tried Macro Express, same issue. I saw it remembers recently loaded baselines if I click the recently selected tab in manage baselines, but for some reason it is only showing me four yet I recently loaded all 15.
    It's a minor irritant, but still an irritant. Any ideas? I can't fathom why they did not just let you select multiples during file load, I wish they'd do an update to allow for that. I downloaded the latest version and still you can only load one at a time.
    Thanks!
    • 969
    Currently, the Load Baseline only allows selecting a single baseline at a time, but it should be an easy enough change to allow multi-select. We'll look to implement the feature in the next build update of PerformanceTest.
    If the baselines are uploaded to our database, you can consider submitting them with an API key and then you can use our online My Baselines to view the results.
    • Strahan
      • Sep 2024
      Nah, I keep them local. Thanks!
