GPU test // Temperature Test error found
  • dom.hum
    • Nov 2024
    I was testing my laptop under GPU test and Temperature test and there are errors found on the temperature exceeding. Is this normal since I have my laptop on overclock? I'm super new to this tuff and somehow I can't find any answers from the search bar which resulted in me starting this thread.
    Generally speaking,low temperatures are good and high temperatures are not so good.
    The max limit depends on your CPU and other hardware.
    Laptop speeds are often thermally limited. So again, generally speaking, overclocking laptops doesn't make sense, as the manufacturer has already calculated the max clock speeds (and thus max power usage and max thermals) that the case and cooling solution can tolerate. Maybe it could make sense if you live in a cold climate, you could squeeze a little bit more out of it.
