Problem: ...disk space on Drive 6: to run the disk test 1.05GB is required,...
  • Mikis
    • Oct 2017
    Click image for larger version  Name:	Passmark_Problem.png Views:	0 Size:	61.2 KB ID:	58203
    Problem; message when testing​: "There is not enough free disk space on Drive 6: to run the disk test 1.05GB is required, O.OOMB is available. Please select another drive in the Preferences dialog.​". What do I do to continue the test?​ Help.
    If the error was not enough disk space, then I think it is likely that there was not enough disk space on the disk being tested. Or the software is corrupted.
    So
    1) Check what drive is selected for testing in the Edit / Preferences window.
    2) Check it has some free space (e.g. 5GB)
    3) Download and install a clean copy of the PerformanceTest software from our site (don't use a hacked / corrupted copy from a 3rd party site)​
