[Baseline excluded] Erroneous data model for Intel Xeon E7-4850 v4
  • verysneaky
    • Jun 2025
    Hi all,
    Tried for the first time today to measure a system since it appears there's no data at all online for the CPU that one I've just bought has: [Quad CPU] Intel Xeon E7-4850 v4. The result was rejected with the following error:
    Baseline has been excluded from average results due to anomalies in the submitted results. [Num CPU Processes - Tested: 128, Expected: 512]
    The Intel Xeon E7-4850 v4 has 16 cores, with 2 logical threads per core. 32x4=128 CPU Processes, so it seems like the expectation of 512 is incorrect (and would explain why there's no data for this CPU, if all measurements are getting rejected). Is there a way to report this data error so that it can be rectified (if this thread isn't sufficient)?
    Or am I misreading this and something else is going on?
    Cheers.
    • 337
    Should be fixed now, though your baseline is currently the only one with that particular CPU (with 4 sockets)
    • verysneaky
      • Jun 2025
      Perfect, thanks Simon. n=1 is better than n=0 if they're looking at buying one or four
