Low performance in 12600kf. can help me?
  • Acedo
    • Jul 2025
    Hello!
    I'm having a problem while playing Dota 2, and that's what brought me here.
    I think the prime number and physics tests indicate something's wrong. It's about 50% below.
    Can you help me fix this?​
ID:	59489Click image for larger version
    These tests use a lot of RAM.
    So maybe something wrong with the RAM setup.
    (for example, you are only running in single channel and/or need to turn on XMP to increase the clock speed).
    • Acedo
      • Jul 2025
      Okay. Thanks for trying to help me David! I think it's activated.
      I'm not quite able to interpret the data... something weird?​
        That screen shot shows that you have 2 x 8GB sticks of RAM.
        It also show the capability of the RAM to run at 3200MT/s (1600Mhz) and that it supports XMP, as defined by the SPD data.
        What it doesn't show is your current settings. Which is the important thing.
        The "memory" tab in CPU-Z has more information. The same information should be available in BIOS.
        • Acedo
          • Jul 2025
          First of all, thank you for the work and time you dedicate to helping and responding to people. Even those of us who only have personal issues, and not ones related to the program itself.
          I think this is the tab. I've seen the uncore frequency vary between 3400 and 3600.
          • Acedo
            • Jul 2025
            Add a system configuration summary:
            Operating System: Windows 10 Enterprise LTSB/LTSC build 17763 (64-bit)
            CPU Type: 12th Gen Intel Core i5-12600KF
            Number of CPUs: 1
            Cores per CPU: 10
            Hyperthreading: Enabled
            Motherboard: TUF GAMING Z690-PLUS D4
            Memory: 16GB RAM
            Videocard: NVIDIA GeForce RTX 3060 Ti
            Hard Drive: KIOXIA-EXCERIA PRO SSD (1TB)
            Hard Drive: Kingston DataTraveler 3.0 USB Device (61GB)
            Hard Drive: Kingston DataTraveler 3.0 USB Device (30GB)
            This Computer
            PerformanceTest Information:
            PerformanceTest Version: 11.1 (Build 1005) WIN64
            PassMark Rating: (N/A)
            System Information:
            System Name: DESKTOP-JHK4BHG
            Model:
            Motherboard Manufacturer: ASUSTeK COMPUTER INC.
            Motherboard Model: TUF GAMING Z690-PLUS D4
            Motherboard Version: Rev 1.xx
            BIOS Manufacturer: American Megatrends Inc.
            BIOS Version: 4301
            BIOS Release Date: 2025/04/29
            Power Source: AC
            Power Mode: N/A
            CPU Information:
            Manufacturer: GenuineIntel
            Codename: Alder Lake
            CPUID: Family 6, Model 97, Stepping 2
            Socket: LGA 1700
            Lithography: 10nm
            Number of CPU's: 1
            Total Cores per CPU: 10
            Total Threads per CPU: 16
            P-Cores per CPU: 6
            E-Cores per CPU: 4
            Clock Frequencies:
            Measured Speed: 3687.0 MHz [Turbo: 4683.5 MHz]
            Multiplier: 37.0X
            Bus Speed: 99.6 MHz
            Front Side Bus Speed: (N/A)
            Timing Error Ratio: 1.000
            Cache per CPU package:
            L1 Instruction Cache: 6 x 32 KB + 4 x 64 KB
            L1 Data Cache: 6 x 48 KB + 4 x 32 KB
            L2 Cache Size: 6 x 1.25 MB + 1 x 2 MB
            L3 Cache: 20 MB
            Memory Information:
            Total Physical Memory: 16GB RAM
            Available Physical Memory: 6GB RAM
            Transfer Rate: N/A
            Memory timings: N/A
            Channel mode: N/A
            Memory Devices:
            Slot 1: DDR4, 8192MB, 3200MHz,
            CMW16GX4M2Z3200C16,
            Slot 2: DDR4, 8192MB, 3200MHz,
            CMW16GX4M2Z3200C16,
            Slot 3:
            Slot 4:
            Virtual Memory: C:\pagefile.sys (3456MB)
            Drive Information:
            Physical Drive 0: KIOXIA-EXCERIA PRO SSD
            Drive Size: 931GB
            Partitions: C:
            Interface Type: NVMe
            Bytes per Sector: 512
            RPM: Solid State
            Drive Serial Number: X1EA10JEKA34
            Physical Drive 1: Kingston DataTraveler 3.0 USB Device
            Drive Size: 57GB
            Partitions: E:
            Interface Type: USB
            RPM: Unknown
            Physical Drive 2: Kingston DataTraveler 3.0 USB Device
            Drive Size: 28GB
            Partitions: D:
            Interface Type: USB
            RPM: Unknown
            Optical Drive 1:
            Volume Information:
            Volume 1: C: [Local Drive]
            File System: NTFS
            Drive Cluster Size: 4KB
            Volume Size (Free space): 930.9GB (827.6GB)
            Volume 2: D: [Removable]
            File System: NTFS
            Volume Size (Free space): 28.9GB (11.9GB)
            Volume 3: E: [Removable]
            File System: NTFS
            Volume Size (Free space): 57.7GB (3.6GB)
            Volume 4:
            File System:
            Drive Cluster Size:
            Video Adapters:
            Video Card 1: NVIDIA GeForce RTX 3060 Ti
            SLI/Crossfire Enabled: No
            Chip Type: GA104
            DAC Type: Integrated RAMDAC
            Memory: 8192MB
            Video BIOS: 94.04.6b.40.30
            Driver Provider: NVIDIA
            Driver Version: 537.58
            Driver Date: 10-4-2023
            Monitor 1: 1920x1080x32 144Hz 96 DPI (Primary monitor)
            Monitor 2: 1920x1080x32 60Hz 96 DPI
            Video Card 2:
            Chip Type:
            DAC Type:
            Memory:
            Video BIOS:
            Driver Provider:
            Driver Version:
            Driver Date:
            Monitor 1:
            Monitor 2:
            Temperatures:
            CPU 0: 39.8C (Maximum: 39.8C)
            CPU Core 0: 29.0C (Maximum: 41.0C)
            CPU Core 1: 26.0C (Maximum: 41.0C)
            CPU Core 2: 25.0C (Maximum: 42.0C)
            CPU Core 3: 26.0C (Maximum: 38.0C)
            CPU Core 4: 28.0C (Maximum: 40.0C)
            CPU Core 5: 26.0C (Maximum: 36.0C)
            CPU Core 6: 29.0C (Maximum: 40.0C)
            CPU Core 7: 29.0C (Maximum: 40.0C)
            CPU Core 8: 29.0C (Maximum: 40.0C)
            CPU Core 9: 29.0C (Maximum: 40.0C)
            CPU Core 10:
            CPU Core 11:
            CPU Core 12:
            CPU Core 13:
            Hard Disk 0: 45.0C (Maximum: 47.0C)
            Hard Disk 1:
            GPU 0: 48.0C (Maximum: 48.0C)
              Memory configuration looks OK. 3200MT/s + 2 channel is all you can expect from your hardware. It is a bit strange that CPU-Z seems to be reporting 3600MT/s however.
              I had another look at the results. They aren't that bad. Here is the distribution for this CPU for Prime numbers.
              Yes, you are under average for this benchmark. But not everyone can be above average (by definition).
              Here is what I think the issue is:
              The Intel 12600KF CPU can support both DDR4 and DDR5 RAM, depending on the motherboard. The best DDR4 can be as good as the bottom end DDR5, but you don't have the best available DDR4. And the top end DDR5 is now significantly better than the low end DDR4. When the 12600KF was released the DDR4 motherboards were cheaper to buy and so was DDR4. So DDR4 made some sense at the time. But DDR5 is now cheaper and faster.
              Click image for larger version  Name:	image.png Views:	0 Size:	64.4 KB ID:	59520​
