BSOD issue with GPU Compute.
  • WayneChang
    • Aug 2025
    When running Passmark11.1 on AMD+Nvidia MXM platforms, selecting the "GPU comput "in 3DMark results in a Blue Screen of Death (BSOD). This BSOD indicates a "dxqkrnl.sys" hang. This issue only occurs with Passmark version 11.1. Version 11.0 works fine. Any suggestions? Thank you.
    dxgkrnl stands for DirectX Graphics Kernel.
    It isn't our file. It is installed as part of Windows. It is a component of the Windows operating system that manages communication between the graphics hardware (GPU), the Windows Display Driver Model (WDDM), and the DirectX APIs.
    So you might have a bad video card driver installed, or a corrupt Windows install. Or maybe a hardware fault.
    Some of the GPU compute tests were updated in V11.1 to be 64bit (previously they were 32bit).
    • WayneChang
      • Aug 2025
      Thank you for your information.
