Help and instructions and faq is not VISIBLE in download link
  • Kangarooo
    • Jan 2022
    • 22
    faq i now after 10 minutes saw on top. no one starts with menu in downloads page to know is there faq and if they know what faq means
    need it in middle of page under download around somewhere
    https://www.passmark.com/products/bu...t/download.php
  • Kangarooo
    • Jan 2022
    • 22
    hello? can you put instructions in there that link? or give admin- ill put if cant put in 3 months
    oh correct place is here. so 2 places i missing faq simple command to run it.
    also needed instructions how to install so it runs. found readmefile now and better to have it in faq.
    https://forums.passmark.com/performa...ons-in-website
    so in readme is no installations commands or apps that are missing to run it. so its a code that isnt running
      • 337
      We will take your feedback into consideration whenever we refresh our site
      Not sure why you think we would give a random person on the internet access to our site
      As for instructions - download installer, double click to install?
      Unless this is about the Linux version (though your link points to the Windows version)
      Also see: https://www.passmark.com/support/bit...issing_lib.php
      For possible commands to run to help install missing libs
