Graphics Test Freezes CPU with Radeon 8500LE
    Posted as reference fo others with :
    >> The advanced 3D graphics test in PerformanceTest freezes
    >> the computer, a re-boot is necessary. Before the
    >> lock up I can see - 754.45 FPS 640x480x16
    >> Radeon 8500LE HAL (pure HW..). I have Directx 9
    >> and AMD 1800, 512M memory. What should I check?
    >> Stephen
    > The #1 support problem is bad video device drviers
    > and this should be the 1st thing you check. Either
    > upgrading or downgrading can fix issues like this.
    > David
    > PassMark
    I got the latest drivers and that fixed my problem.
    Thanks.
    I was running ok, I thought, with the old drivers.
    Stephen
