exporting results Help
  • the_sixth_biome
    • Dec 2006
    I cant believe that to export results to a txt file it makes all the data into 2 very long HORIZONTAL lines! It is almost impossible to enter and backspace enough to get the data in columns suitable to post it here! HELP! There must be an easier way!
    Yes, the (tab delimited) text export in V6.0 is meant for importing results into other programs, such as spreadsheets. We have added a new Formatted text export in V6.1 due for release this week.
    If you would like to try a Beta version, here it is:
    http://www.passmark.com/ftp/petst611000_2.exe
    Best regards,
    Ian
