dissapointing 2d scores, need help
  • James Coolman
    • Mar 2007
    Can anyone advise me on settings to improve my scores?
    Test Name This Computer
    CPU - Integer Math 237.6
    CPU - Floating Point Math 643.7
    CPU - Find Prime Numbers 684.2
    CPU - SSE/3DNow! 5710.1
    CPU - Compression 6009.4
    CPU - Encryption 36.4
    CPU - Image Rotation 1199.7
    CPU - String Sorting 3896.3
    Graphics 2D - Lines 214.4
    Graphics 2D - Rectangles 297.6
    Graphics 2D - Shapes 6.6
    Graphics 2D - Fonts and Text 318.6
    Graphics 2D - GUI 253.7
    Graphics 3D - Simple 2033.1
    Graphics 3D - Medium 563.5
    Graphics 3D - Complex 55.0
    Memory - Allocate Small Block 2603.2
    Memory - Read Cached 2060.2
    Memory - Read Uncached 2028.7
    Memory - Write 1784.8
    Memory - Large RAM 635.5
    Disk - Sequential Read 41.7
    Disk - Sequential Write 72.7
    Disk - Random Seek + RW 2.9
    CD - Read 1.9
    CPU Mark 1593.5
    2D Graphics Mark 839.2
    Memory Mark 673.7
    Disk Mark 424.1
    CD Mark 229.2
    3D Graphics Mark 66.7
    PassMark Rating 782.4
    System information - This Computer
    CPU Manufacturer:GenuineIntel
    Number of CPU: 1 (2 Core(s)/CPU, 1 Logical(s)/Core)
    CPU Type: Intel(R) Core(TM)2 CPU 6700 @ 2.66GHz
    CPU Speed: 2671.3 MHz
    Cache size:Unknown
    O/S: Windows XP (WIN32)
    Total RAM:2047.0 MB.
    Available RAM:1454.9 MB.
    Video settings: 1600x1200x32
    Video driver
    DESCRIPTION:
    NVIDIA GeForce 8800 GTX
    MANUFACTURER:
    GeForce 8800 GTX
    BIOS:
    Version 60.80.0A.00.00
    DATE:
    12/19/06
    Drive Letter: C
    Total Disk Space: 465.8 GBytes
    Cluster Size: 4 KBytes
    File system:NTFS
    The score's aren't all that bad. You might be ble to get them higher with,
    1) Better device drivers. It is well documented that the 8800 had driver issues.
    2) Turning off some of the XP display options from the control panel.
    3) Switching to 16bit color, instead of 32bit color.
    but options 2) and 3) will effect the way other software looks and behaves.
