I'm running BIT Pro under RHEL4, and am seeing some weirdness trying to test /dev/ttyS1. I've been able to test net, disk, usb, etc so far with success.
However, when I plug in the PassMark RS-232 loopback and run the test, it always shows 0 cycles, 0 operations, 0 errors throughout the 5min test cycle.
I'm running USB at the same time, and it works fine. Confirmed by inserting faults during the run.
BTW, I have confirmed that both ttyS0 and ttyS1 are recognized by issuing commands similar to:
[root@oscar root]# dmesg | grep tty
ttyS0 at 0x03f8 (irq = 4) is a 16550A
ttyS1 at 0x02f8 (irq = 3) is a 16550A
[root@oscar root]# setserial -g /dev/ttyS[01]
/dev/ttyS0, UART: 16550A, Port: 0x03f8, IRQ: 4
/dev/ttyS1, UART: 16550A, Port: 0x02f8, IRQ: 3
I've confirmed that ttyS0 works, as I use it as my console port to run the test. I just can't seem to get the test to work on ttyS1.
My config file has:
Device ttys1
TestMode Loopback
SendReceive 3500
BaudRate 9600
Anyone have suggestions on things to check, or additional settings I might need to make?
Thanks!
Paul
My config file has:
Device ttys1
TestMode Loopback
SendReceive 3500
BaudRate 9600
Thanks!
Paul
