Testing USB Flash drive - what Serious Error means?
  • zalekbloom
    • Jul 2009
    I am testing my 16BG USB Flash drive. During a test I received 5 Serious Errors - out of 16gb only 12 gb were verified.
    I used options:
    Random data pattern
    Slow drive threshold 1 mb/sec
    Does it means I need to get rid of flash drive?
    Thanks,
    Zalek
    Depends what the errors were? Brief slowdowns aren't too much of a worry with USB drives.
    • zalekbloom
      • Jul 2009
      DETAILED EVENT LOG
      LOG NOTE: 2009-07-28 22:17:09, Status, PassMark BurnInTest V6.0 Std 1011
      LOG NOTE: 2009-07-28 22:17:09, Status, Main Tests started
      SERIOUS: 2009-07-28 22:19:30, Disk, C: Data Verify failure
      LOG NOTE: 2009-07-28 22:19:30, Disk, File: C:\BurnInTest test
      files\~bittestC00001, Value Read: 36, Value Expected: 38, Offset 583,
      Ops: 501219328
      LOG NOTE: 2009-07-28 22:19:30, Disk, Disk Error (C: Data Verify
      failure in Cycle 0 with pattern Random data pattern
      SERIOUS: 2009-07-28 22:21:58, Disk, C: Data Verify failure
      LOG NOTE: 2009-07-28 22:21:58, Disk, File: C:\BurnInTest test
      files\~bittestC00002, Value Read: 168, Value Expected: 170, Offset
      905347, Ops: 1003487232
      LOG NOTE: 2009-07-28 22:21:58, Disk, Disk Error (C: Data Verify
      failure in Cycle 1 with pattern Random data pattern
      SERIOUS: 2009-07-28 22:24:33, Disk, C: Data Verify failure
      LOG NOTE: 2009-07-28 22:24:33, Disk, File: C:\BurnInTest test
      files\~bittestC00003, Value Read: 145, Value Expected: 147, Offset
      106807575, Ops: 1605369856
      LOG NOTE: 2009-07-28 22:24:33, Disk, Disk Error (C: Data Verify
      failure in Cycle 2 with pattern Random data pattern
      LOG NOTE: 2009-07-28 22:25:21, Status, Test run stopped
      Thanks,
      Zalek
        The drive is bad.
        It might even be one of the fake USB drives that are on the market.
