How to keep test data when error occurred?
  • rakorei
    • Apr 2011
    Dear PassMark Support Forums
    I run burnintest on a usb flash drive with setting command -k and auto stop ,
    but I can't see any testdata left when encountered a Verification error.
    So I try command -KA , but it will become sleeping state when testdata volume reach the capability of the drive.
    How can I keep testdata when error occurred in unknown round?
    Is there any setting missing or need other command?
    Best Regards,
    Rako
    I checked and the -k option and it does not delete the files during the test, but does on ending the test. We will change this in a future version of BurnInTest.
    You will need to use -KA for now, or -K and don't stop the tests and investigate the test files while the test is running.
