USB3.0 Loopback test "USB driver reported send error" with Intel Skylake-U platform
  • DFI
    • Oct 2016
    Hi, PassMark
    We have a problem on USB 3.0 Loopback test error with Intel Skylake-U platform.
    In case burn in test report " USB driver reported send error ".
    BTW, We have passed USB 3.0 eye diagram SI test.
    Do you have any suggestion in this case?
    Test condition:
    Burn In Test V8.1 build 1018
    Loopback dirver Win7 x64 V1.2.3
    Loopback FW V2.0
    OS win8.1 x64
    Intel USB 3.0 Host controller driver v2.0.0.5
  • HamidK (PassMark)
    • Jul 2016
    • 47
    The result of your test indicates only two failures over 16 hours of test. If there were signal integrity issues in your design, the rate of failures would be much higher. The power supply of the USB port might be the source of issue. Noisy power supply or voltage spikes can affect the receiver part of the USB3 loopback plug and cause transmission failures.
