I am trying to use BITPro 5 and Hmonitor 4.2.14 pro to produce test certicates but cannot get hmonitor data into bitpro as I cannot choose the sensor ( nothing in drop down box).
Is there any thing else I have to do to get the progams talking to each other
Temperature Monitoring
Tags: None
Temperature monitoring
Further to my post, have tried speed fan which displays temps fine while test as running but does retain display info when tests end. -
I have contacted Alexander Berezkin from Hmonitor and he has asked that you contact him with and supply a hardware report from Hmonitor.
support [at] hmonitor.com
We will investigate the Speedfan issue reported shortly.
Best regards,
IanComment
Registered for the beta program with hmonitor, - current beta version fixed that issue- BUT as I am trying to add temperture to my end of repair test burn in speedfan seems a better solution if BITPro would retail result not just display while testing otherwise I will have install ans register a copy of hmonitor for every repair??Comment
The temperature readings are written to the log file at the end of a test, so in this sense they are retained or usable after the test completes. For example a Normal level log file will contain a Result summary with the temerature readings at the end of the test, as follows:
RESULT SUMMARY
Test Start time: Mon Mar 20 10:39:52 2006
Test Stop time: Mon Mar 20 10:40:00 2006
Test Duration: 000h 00m 08s
Temperature Sensor 1 (Min / Current / Max): 49.0 / 49.0 / 49.0
Temperature Sensor 2 (Min / Current / Max): 43.0 / 43.0 / 43.0
Temperature Sensor 3 (Min / Current / Max): 46.0 / 46.0 / 48.0
CPU - Maths 1 100 PASS 0 No errors
TEST RUN PASSED
Does this meet your requirement, or do you really need it to display this on the main Window?
Best regards,
IanComment
