Sound error show "operations reported in timeout period" occurred while BurnIn Test
  • Peter_Tseng
    • May 2018
    Hi Partner,
    Our team run Burnin test occur sound error
    Could you analyse the Log , which cause this problem.thanks.
    OS: Win 10 RS4
    CPU: AMD Stoney APU.
    Audio chip: RealtekALC273
    Test software: Passamrk 8.1.1025
    Test items:
    CPU/ RAM/ Video/ 2D,Graphics/3D Graphics/ Disk/ Sound/ Network set every items's loading to 100.
    Set " Auto Stop after" minutes to 240mins, then click green arrows to start the test.
    Fail item: Sound Error"operations reported in timeout period"
    I put the log on the attachment.
    • 11118
    Don't set everything to 100%. It doesn't do what you think.
    Instead see the recommendations here
    https://www.passmark.com/support/bur...usage.htm#load
    Under the heading, "What duty cycle setting should be used?"
    See also
    https://www.passmark.com/forum/burni...timeout-period
    • Peter_Tseng
      • May 2018
      Thanks~David.
      We change CPU loading to 95% as docment suggestion. but still occur Sound error show "operations reported in timeout period"(fail, 3/14 units)
      and then we change CPU to 80% , that can pass(pass, 0/14 units). so you mean that is normal behavier if run all system test ,CPU load can't put so high, right?
      we change CPU to 80% ,that can be accepted?
        • 11118
        You should be able to run the tests very near 100% CPU load (not be be confused with 100% duty cycle, which is a different thing).
        But as pointed out in this post,
        "'No operations reported in timeout period' for the sound test means the sound driver crashed or the whole system was super slow. If the system was super slow it might be due excessive load and / or due to memory leaks, which cause a lack of free RAM, which in turn cause disk swapping. Once you start disk swapping then the system can fairly quickly start to thrash under high load. Thrashing then leads to timeouts and crashes."
        • Peter_Tseng
          • May 2018
          I run ONLY select Sound to 100%, and other test item not select with 5 units yesterday . the result is PASS.
          I consider this issue happen is the whole system was super slow. but could you suggestion another test to narrow down.
          How to proof the definite cause by system was super slow. thanks a lot.~~
            • 11118
            If you only run the sound test does system memory usage creep up over time. It shouldn't.
            If you open Windows Resource monitor do you see lots of read and writing to the Page file (c:\pagefile.sys). As this would be thrashing. Resource monitor can also display "Hard Faults/sec" this value should stay reasonably low after the initial launch of the tests.
            Once the error occurs can you play a sound file with an external application?
            • JerryX
              • Feb 2015
              we also encounter this issue on AMD platform,and it's pass if change CPU/RAM loading to 50%.
              how to set the CPU/ RAM/ Video/ 2D,Graphics/3D Graphics/ Disk/ Sound/ Network's loading for AMD platforms?
                • 11118
                See my initial reply in Post #2.
