Burn in Test 9.1 bitconfig verification
  • NPI.GUY
    • Jul 2015
    • 13
    Is there a way to verify the configuration file that was loaded? In the older version of Burn in test, you could see the filename of the loaded configuration file. But I haven't been able to see it in Burn in test 9.1.
    I'm trying to add this as a checked item when having technicians load up the software.
    Currently no I don't believe there is (it may have gotten lost in some of the V9 user interface changes).
    We're about to put out a new release so we'll add in a way of seeing the currently loaded configuration file.
      This has been added to the 9.2 release available now.
      • NPI.GUY
        • Jul 2015
        • 13
        Is there also a way to load the program "Test Preference" Defaults?
        I'm trying to make a list of changes I have made, but I don't see a "restore defaults" for the Test Preferences section.
        I can only see Restore Defaults for Test Duty and Cycles.
          There isn't a restore defaults for the entire config, you would need to delete the LastUsed.bitcfg file so it would recreated next time BurnInTest is launched.
          • NPI.GUY
            • Jul 2015
            • 13
            I tested the new version of burn in test 9.2 and found the filename for the configuration file unreadable
              Space to display the file name is a bit limited here, we can increase the field size a bit more and look at making it double the height, so a really long config name may wrap around to a second line. We'll trim the .bitcfg as well.
