How to Start BurnInTest V9.2 (1006) at a x-y coordination of a width-height window
  • DennisV
    • May 2021
    • 14
    I need help to Start BurnInTest V9.2 (1006) at a x-y coordination of a width-height window.
    In my test environment, we have multiple Windows views/windows. We have been using a utility called, cmdow, to start our various test windows at a desired x-y coordination and size. Unfortunately, cmdow works for windows/views of all type of applications, but it does not work for BurnInTest.
    Also, we use AutoHotKey (AHK) to do transparency for our windows/views. Again, my AHK script works for for windows/views of all type of applications, but it does not work for BurnInTest.
    Please help
    Dennis
    There is a a -L command line argument for BurnInTest that will place the window as specified co-ordinates;
    -L [x,y,wt,ht]
    Starts BurnInTest with the main window located at top-left co-ordinates x, y and with width wt and height ht. It is important that there are no white space characters in [x,y,wt,ht] specifications.
    Example: -L 50,50,800,600
    For the AutoHotKey transparency, potentially this only works for applications that used standard windows and dialogs where as BurnInTest uses quite a number of custom draw elements throughout it's UI now.
    • DennisV
      • May 2021
      • 14
      Tim,
      Thank you for your pointer.
      Dennis
