Auto Update serial number in .bits script (for logs)
  • vikas711
    • Aug 2022
    1. How can i auto set the serial number in the .bits script through the command line, without opening the script file.
    SETSERIAL "1234"
    SETLOG "E:\BurnInTest\1234.htm"
    RUN CONFIG "E:\BurnInTest\Test01.bitcfg" # this could be fixed
    i.e.
    bit.exe -s burnIn_script_test.bits {some argument} #(one can enter is serial number)
    2. For USB, if its detected as E or F, if machine changes
    How can i handle that in script, without opening through command line (one can enter is E or F)
    1. You can set and use an environment variable, eg %serial%, and it should be replaced in the script when BurnInTest loads it (using the windows function ExpandEnvironmentStrings).
    2. If you're running from a USB drive then you should be able to use a relative path like "1234.html". Also you will need to use "LOAD Test01.bitcfg" before doing "RUN CONFIG".
    • vikas711
      • Aug 2022
      Thanks TIM,
      Anyways we can not do anything at laptop side (set env var).
      Other way like, i will try to write .bitcfg everytime with new serial number (log file name), (using python or LV)
      • vikas711
        • Aug 2022
        Hi TIM,
        If I test my system from USB & keep on changing the system. It will work right? I need to test few systems, one at a time is ok.
        Can be done through USB installation right? or suggest the right way.
