Announcement
No announcement yet.
BIT Closes itself when detecting temperature sources.
  • Filter
  • BIT Closes itself when detecting temperature sources.
    My issue is pretty much what the title says. I start BIT (i have tried 10.1_1004 through the newest available version), and the BIT window will close itself when the text "detecting temperature sources" appears on the bottom of the window. When i run BIT in debug mode(adding -u to the argument list), the issue does not occur and BIT runs normally. BIT also runs normally when i disable temperature logging entirely.
    I have included all of the debug logs i got and hope there is a quick fix i can apply shortly (looks like it wont let me upload the trace logs).
  • #2
    Can you please email us the SysInfoLog.txt that was created when running in debug mode.
    • #3
      I sent the file that you requested! Thanks for the help!
      • #4
        I have the same Problem.
        In Linux (deb 11) and BIT V5.0 Build 1004 crashes in gui mode when i click on the Temperature Tab. When i use the cmd version no Temp sensors are detected.
        And for the future, please add a requirements.txt to the package, because there is nowhere a complete list of software dependencies for BIT in linux...
