Ethernet Error ratio exceeded
  • QQOO
    • May 2024
    My platform is intel ADL-N and runs the CPU, Memory, Disk, 2D, 3D, Sound and Ethernet all with 100%. Unfortunately, I got the ethernet with Error ratio exceeded after several hours. The system can run over 168 hours without any error as stress Ethernet only with 100%. Any suggestion for this symptom? Thanks
    See this page for suggestions about what duty cycle to use for the tests.
    Generally it doesn't make sense to run everything at 100% at the same time.
    For the errors, you should try and determine the nature of the errors. For examples, timeouts under very high load might be expected. Data corruption on the other hard might be more serious.
    • QQOO
      • May 2024
      Thanks for the reply.
      BurnInTest - What duty cycle setting should I use
      It said " CPU load is around 95% to 99%" how can I check my CPU is at 95%? Windows CPU usage?
      ​ The log file is as below, if it is timeout then causes this issue, what can I do?
      RESULT SUMMARY
      Test Start time: Fri Mar 1 17:15:42 2024
      Test Stop time: Mon Mar 4 09:56:44 2024
      Test Duration: 064h 41m 02s
      CPU 13720 129 Trillion PASS 0 No errors
      Memory (RAM) 3431 27.338 Trillion PASS 0 No errors
      2D Graphics 35055 3.576 Million PASS 0 No errors
      3D Graphics 118 3.551 Million PASS 0 No errors
      USB 3 (PMU34PQV0H 5Gb/s) 2653 40.009 Trillion PASS 0 No errors
      USB 3 (PMU36RW5V2 5Gb/s) 2661 40.115 Trillion PASS 0 No errors
      USB 2 (PMSH57IA 480Mb/s) 2235 183 Billion PASS 0 No errors
      USB 2 (PMU3A621 480Mb/s) 2234 183 Billion PASS 0 No errors
      USB 2 (PMU3A5JN 480Mb/s) 2233 182 Billion PASS 0 No errors
      USB 2 (PMU3DB7Y 480Mb/s) 2231 182 Billion PASS 0 No errors
      Video Playback 17438 223194 PASS 0 No errors
      Serial Port 3 1451 1.004 Billion PASS 0 No errors
      Serial Port 4 1455 1.006 Billion PASS 0 No errors
      Serial Port 5 1449 1.002 Billion PASS 0 No errors
      Serial Port 6 1450 1.003 Billion PASS 0 No errors
      Disk (D 66368 58.962 Trillion PASS 0 No errors
      Disk (E 2969 7.764 Trillion PASS 0 No errors
      Network 1: Realtek PCIe GbE Family Controller 213 8.555 Million FAIL 6 Network test alarm. Error ratio exceeded
      Network 2: Realtek PCIe GbE Family Controller #2 213 8.554 Million FAIL 6 Network test alarm. Error ratio exceeded
      TEST RUN FAILED
        See this page for suggestions about what duty cycle to use for the tests.​
        This also seems to be a duplicate post and you are using old V9 software.
